RX EQ, only seems to effect Slice A on the 6600M
John Orjias
John Orjias Member ✭✭
just trying diversity mode and discovered the EQ only effects the main antenna on Slice A, so i turned off diversity mode and discovered it also has no effect on slice B. Is there a way to make it global for all slices that are in a Phone mode?
  • Lasse Moell
    Lasse Moell Member ✭✭
    edited May 2020
    Try this: select slice B, change mode from what you have to something different, and then go back to the mode you were using.... This should enable RXEq on slice B
  • John Orjias
    edited May 2020
    thanks that did it, is that a bug or by design?
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited May 2020
    Think it is a glitch that needs to be fixed, you have to wake it up
