RX EQ, only seems to effect Slice A on the 6600M
John Orjias
just trying diversity mode and discovered the EQ only effects the main antenna on Slice A, so i turned off diversity mode and discovered it also has no effect on slice B. Is there a way to make it global for all slices that are in a Phone mode?
Try this: select slice B, change mode from what you have to something different, and then go back to the mode you were using.... This should enable RXEq on slice B0
thanks that did it, is that a bug or by design?0
Think it is a glitch that needs to be fixed, you have to wake it up0
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
