RX EQ, only seems to effect Slice A on the 6600M
John Orjias
just trying diversity mode and discovered the EQ only effects the main antenna on Slice A, so i turned off diversity mode and discovered it also has no effect on slice B. Is there a way to make it global for all slices that are in a Phone mode?
Try this: select slice B, change mode from what you have to something different, and then go back to the mode you were using.... This should enable RXEq on slice B0
thanks that did it, is that a bug or by design?0
Think it is a glitch that needs to be fixed, you have to wake it up0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 36 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
