WSJT, FT8, stations not showing up in Band Activity window, How to fix
David Sturm
Hello all, I looked at the other answers
and none has worked for me.
I will be including a photo of a screen shot. My DAX is on channel 1, I have stopped and started DAX and still the same. Annoying to say the least.
Any suggestions would be greatly appreciated.
Thx
David
WB4OZM/HC5DX
Thx
David
WB4OZM/HC5DX
Which version of WSJT are you running?0
Has it ever worked? Can you decode any other modes, try WSPR. Is your clock set correctly? Current version is 2.2.0
Good luck Vidas0 -
I had to reinstall WSJT once because of an odd problem like this. Also if you use Slicemaster, you need to let it load all of its connections first, before activating WSJT. Also double check your receive level and make sure the gain structure is not off and distorting the decoding. Good luck!
Pat
I had this happen, and then I downloaded and installed the latest version of WSJT-X and that solved the problem.
The lastest
Hola , Yes, when I first installed the program it worked like a charm. I have the current version.
I'll try and remove the program and re-install it. My NetTime clock is working too.'
Maybe there is a setting in the program that I may have un clicked?
are you seeing signals in the waterfall?
Can you post an image of your radio and audio settings?0 -
Nice thing about Slicemaster is it takes care of the settings in WSJT by itself. Also are you running any other programs that might interfere with WSJT?
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
