Profile
Auto save does not save profiles! Only what has been changed while you have been operating.... you have to actually go in to profiles and initiate the change. And back it up, to make it permanent and recallable. If you find that you changed something and don’t want it. Recall the appropriate profile that you originally created. If you did one?
I have never had a radio crash and have no problems when windows updates.
I believe the profiles are overwritten when you change bands. Before changing to another profile I always reload the current profile. That way if SSDR wants to overwrite my profile it will be with the original settings so there will be nothing changed.
It would be easy but time consuming to make a list of items that get overwritten. So far we know that the power setting in your profile will be overwritten, I have checked mode and it is not overwritten. I do not think the settings in the Microphone profiles are changed. Nor are the AGC-T setting. More testing is needed.
Speaking of AGC-T, I am enjoying that feature a lot more since assigning that control to a button on my FlexControl. My mouse is unreliable when trying to make small adjustments to AGC-T. That slider should be longer. Or maybe it's my shaky hand.
-Robby
HP3SS0 -
You can just use the mouse wheel to adjust smoothly.0
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
