Dead Flex 6600
Please HELP!!!!
Radio is non-responsive. Won't power up. Power supply is working. Cable is
plugged in.
For some reason my antenna memory wasn't saved and I transmitted
into the wrong antenna.
Seems like an internal fuse... maybe?
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    Is the Power Button blinking?
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited May 2020
    If there is no sign of life, start a help ticket and they would be glad to help.
  • Howard Koenig
    Howard Koenig Member
    edited May 2020
    Hmmmm... Just came back on... all by itself!  well that was weird.
  • Bill -VA3WTB
    edited May 2020
    Ok, so it is back up, good. now keep an eye on it Howard. It is possible your SD card has some corruption issues. Corruption will show two types of problems. It can make your radio do strange things, start up problems, lose of persistance, The other problem is that it may even stop your radio from starting completely.
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    now that it is up and running what version are you running?
    If your not up to v3.1.12 or the latest version of 2 then I would upgrade as soon as you can and HOPE it is not the SDCard and the SDCard doesn't crash again before you get the upgrade done.
    V3.1.12 and the latest ver of 2 are supposed to fix the SDCard problem.
    73's
    Bret
  • Bill -VA3WTB
    edited May 2020
    Bret, this is were it gets tricky. Only if your SD card is perfect is the upgrade any good. What has been happening is some people have upgraded but the card had some lingering bad data on it from the last version, now, even with the upgrade they still have problems. In this case the card needs a full format, or a new card to fix it.
  • Howard Koenig
    edited May 2020
    Running 3.1.12 which is supposed to fix the sd card issues?
    It has done strange things before. BTW are they ever going to fix the DAX problem when it
    becomes distorted after a while?
  • Bill -VA3WTB
    edited May 2020
    Also, this is making things harder to help people complaining that their radio is doing strange things. Is it an SD card with bad data, or do they need a factory reset? the problems that are showing up are very similar to each other. It has been found out that a n bad SD card can make the radio do strange things, messed up persistence, strange start ups, profiles missing or changed without the op doing anything. The lines have blurred. Now that the SD card problem is behind us, trouble shooting will be a little easier.
  • Bill -VA3WTB
    edited May 2020
    3.1.12 fixes the problem of a card becoming corrupt. but not if the card already has problems from before. I don't know anything about what Flex is working on right now.
  • Joe - KC2TN
    Joe - KC2TN Member ✭✭
    edited May 2020
    After upgrading to 3.1.12, you should also do a factory reset anD restore your backed up profiles. This rebuilds a potentially corrupted database on the SD card.
  • N9VC
    N9VC Member ✭✭
    edited May 2020
    If it would do it again, suspect the obvious. The power supply was on and you say it
    was plugged in, but the plug could have been slightly loose. Check DC at the connector
    on the radio to be sure you have the right voltage there. If the connection was to be
    intermittent or poor, the voltage drop could be significant and hence, the radio seemed
    to dead. Power poles can be notorious for that.
  • Bill -VA3WTB
    edited May 2020
    Yes, you can have a corrupted data base, but an un corrupted SD card. If he card is Corrupted a new data base will not fix the card. but we can fix the persistance data base.
    To fix a bad persistance data base, you don't want to use a saved profile. Export your profiles with the preferences un checked, then import that profile back into the Flex with the preferences un checked. When you restart the radio a new fresh persistance data base is created.
