Profile Management Suggestion
Glenn Depp
For those of us with many profiles containing slice info for frequencies I think it would be a new valuable inclusion to be able to sort those into groups. Kind of like folder management. Being able to make a folder in the Profile Manager so someone can quickly locate the profile they are looking for would be a nice to have addition. I have many profiles, some include 1, 2, 3, or 4 slices to be open. I use multiple slices periodically in SmartSDR, but I also need to have 3 or less so I am able to utilize my Maestro as well. Just believe being able to group profiles into something like folders would be helpful.
2
I have over fifty profiles. When I make a new one I start with the band :eg "20M_ssb" or say "40M_ft8". As result they automatically are put in order. You might try that until your wish comes true.
VE3DZP0 -
Another, more flexible option is just to make your own group and prefix each name with that group. For example A - Day Phone, A- Day CW, B- Night Digital, etc. These will sort together into "groups"0
I had posted this over on the FB Flex Enthusiasts site but for got to post here.
I'm with you on a need for a more robust Profile management tool. I understand it's being worked on.
Profiles seem to be the established method to get the proper settings configured for each Band/Mode you change to without having to reset several parameters each tome you change bands/mode. With ALL the various bands, modes, power requirements, mic's, contesting setups, equipment variations, etc, etc, etc, you can see why something is needed. These combinations can cause a really long list of selections to accumulate.
Rather than have a separate menu item that you need to select and then search through this potentially long list of selections; perhaps as you rollover a "band button" with your mouse, a pop-up menu with a short list of the appropriate modes listed would appear. This may be a better selection process.
You can still have the profiles menu to create your profiles to select from, but a modified selection process might be easier and quicker.
Also, the profiles menu needs to be in a directory format with renaming, sorting and/or collapsing capability.
If this Profiles Auto-save feature is going to persist, and I'm forced to create Default (or Golden) profiles, then I'd like to see a way to hide them until needed. or just use a RESET button to restore the last used profile to it's default.
I do already have an order to how I label each profile. It does "help" to keep them organized but I too have a long list as I do not only use radio for Amateur Use.
Groups dont help the long listing we generate over time. Just make an organization of a long list.
Has Flex commented if this is being considered or in the works? I have come to rely on profiles but as others have commented, the list is very long. Yes, you can begin each name with a band number but that still results in a VERY long list. It really would be nice to have folders labeled with the band or application. That would neaten things up and speed up selections. Jim KD1I
- 112 SmartSDR+
- 944 Maestro
