SO2R & N1MM+ ?
W2ECK
SO2R & N1MM+ ?
-I have N1MM all setup to run SO2R with a Slice A & B open on different freqs on my Flex 6600. But when I start up N1MM, its Entry window 2 (Slice
is on the same freq as window #1 and Slice A. I do have two different CAT ports set up and assigned in N1MM’s Configuration. So N1MM Entry window 2 is not following the 6600 Slice B freq.
- Anyone have any tips on where to look to solve this problem?
73 Paul w2eck
Figured this one out by digging thru the archives one more time. Found a 2 year old posting from 8P9EH with a picture that showed me right away my error. In the SmartSDR CAT settings for the 2nd radio I had not selected Slice B. So changed that and now each Entry window in N1MM+ is showing the correct (different freqs). Not sure if anyone else has had this problem, but hope this helps.
73 Paul w2eck1 -
Any idea how to get the rig to NOT mute a slice when you toggle to TX on the other?
--Jeff, W0ODS
(struggling Noob)
Jeff,
push ~ button. It is on the left from "1" and below ESC button.
73! Boyan0 -
Thank you! Much appreciated.
In the interest of becoming less helpless - Was that answer found in the N1MM or the SSDR documentation?
--Jeff
Hi Jeff,
it is N1MM key toggling Stereo/Mono
https://n1mmwp.hamdocs.com/setup/keyboard-shortcuts/
73! Boyan LZ2BE
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
