SO2R & N1MM+ ?
W2ECK
W2ECK Member ✭✭✭
SO2R & N1MM+ ?
-I have N1MM all setup to run SO2R with a Slice A & B open on different freqs on my Flex 6600. But when I start up N1MM, its Entry window 2 (Slice B) is on the same freq as window #1 and Slice A. I do have two different CAT ports set up and assigned in N1MM’s Configuration. So N1MM Entry window 2 is not following the 6600 Slice B freq.
- Anyone have any tips on where to look to solve this problem?
73 Paul w2eck
  • W2ECK
    W2ECK Member ✭✭✭
    edited May 2020
    Figured this one out by digging thru the archives one more time. Found a 2 year old posting from 8P9EH with a picture that showed me right away my error.  In the SmartSDR CAT settings for the 2nd radio I had not selected Slice B. So changed that and now each Entry window in N1MM+ is showing the correct (different freqs). Not sure if anyone else has had this problem, but hope this helps.
    73 Paul w2eck
  • Jeff Woods
    Jeff Woods Member
    edited May 2020
    Any idea how to get the rig to NOT mute a slice when you toggle to TX on the other?
    --Jeff, W0ODS
    (struggling Noob)
  • Boyan LZ2BE
    Boyan LZ2BE Member ✭✭
    edited May 2020
    Jeff,
    push ~ button. It is on the left from "1" and below ESC button.
    73! Boyan
  • Jeff Woods
    Jeff Woods Member
    edited May 2020
    Thank you!  Much appreciated.
    In the interest of becoming less helpless - Was that answer found in the N1MM or the SSDR documentation?
    --Jeff
  • LZ2BE
    LZ2BE Member ✭✭
    edited May 2020
    Hi Jeff,
    it is N1MM key toggling Stereo/Mono
    https://n1mmwp.hamdocs.com/setup/keyboard-shortcuts/
    73! Boyan LZ2BE
