TX Band Settings not working in V2.6.2.50
Steven Linley
I can overload my amp! I see 40m for 15 Watts max. But in TX I have max power set to 22 Watts.
Those dreaded words "We have an upgrade for you"
Any time you change anything it overrides the TX Band settings, and auto saves... Puff, I really dislike auto save for profiles. If you have 2 persons on the same radio and both are using the same profile, any change one user makes gets changed on the other. This is vary painful when you are trying to use PC as you microphone remotely and MIC locally.0
Recent SSDR critical update covered SD card issues. Have these SD card failures become worse with the profile auto save feature?
Yes!!!0
YES0
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 306 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
