TX Band Settings not working in V2.6.2.50
Steven Linley
I can overload my amp! I see 40m for 15 Watts max. But in TX I have max power set to 22 Watts.
Those dreaded words "We have an upgrade for you"
Any time you change anything it overrides the TX Band settings, and auto saves... Puff, I really dislike auto save for profiles. If you have 2 persons on the same radio and both are using the same profile, any change one user makes gets changed on the other. This is vary painful when you are trying to use PC as you microphone remotely and MIC locally.0
Recent SSDR critical update covered SD card issues. Have these SD card failures become worse with the profile auto save feature?
Yes!!!0
YES0
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
