3.1.12 Profile Manager
Mark_WS7M
Member ✭✭✭
After upgrade to the official release 3.1.12 I cannot get the profile manager window to come up.
Mine works just fine, more info like OS
Ok never mind. It turned out to be WAY OFF SCREEN probably due to messing with monitors. Sorry for the post.1
I have it working fine here.
But when I exported the profiles which I saved to both the normal DIR I typically keep all Profiles in and the CLOUD.
When I imported them back, after a complete shutdown, the normal DIR Profiles had missing data, where the CLOUD profiles where 100% perfect.
Thanks to Ken at FRS and others, thankyou for getting these profiles squared away.
Tom W3FRG
Been there done that Mark. I got a new monitor card with 4 HDMI outputs, was working much faster than my previous setup, then a week or so ago, the card took a dump and I had to revert back to 2 monitors the motherboard can support. Had many windows locked to monitors no longer there, found another window yesterday that I had to bring back in view.
Windows really needs a "bring all windows to this monitor" feature.0
I just tries to drag a window off the display area of the monitor and Windows will not permit that.
The Windows key-P may be an option as well for an odd situation.0 -
You can't drag off. But if you have a window on monitor 3 and you remove monitor 3, physically. IE it is no longer in your system the the window still tries to be on monitor 3 and is not visible.
You can move it back if you are tricky but it would be nice to have a recovery function.0 -
I think the Windows Key-P command will allow you to put everything on a single monitor. I can't try that right now. At work I have multiple monitors, not here at home.
Usually I set up multiple virtual desktops and switch between them even with multiple monitors. I don't have space for multiple monitors in the shack.0 -
Ok I tried that and it did some strange stuff. It switched how the desktop is displayed. It didn't seem to matter what I selected but a window I know is currently on a disabled monitor did not appear for me.0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
