Is it possible to align slice to the left Flex 6400m front panel?
Ross Slater
When using a DIGU 3.5 band width as an example is it possible to keep the slice aligned to the left instead of the middle?
You can move the slice to the left side by putting your finger on the panadapter to the right of the passband and drag to the left.
I saved it as a global profile, shut down the Maestro and restarted. The slice remained in the last position (to the left). I moved the slice to the right then loaded in the global profile I had just saved with the slice to the left. The slice moved back to the left.
Hi I tried what you said and it does go back to the left but as soon as I transmit it's right back to the center again.
I did not try to transmit. I guess it tries to center your to frequency. Dave wo2x0
I read a suggestion to use B slice and set it t same frequency as A then I can move the slice where i want it. Thanks for your input.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
