Is it possible to align slice to the left Flex 6400m front panel?
Ross Slater
Ross Slater Member ✭✭
edited June 2020 in FLEX-6000 Signature Series
When using a DIGU 3.5 band width as an example is it possible to keep the slice aligned to the left instead of the middle?
  • David Decoons, wo2x
    You can move the slice to the left side by putting your finger on the panadapter to the right of the passband and drag to the left.
    I saved it as a global profile, shut down the Maestro and restarted. The slice remained in the last position (to the left). I moved the slice to the right then loaded in the global profile I had just saved with the slice to the left. The slice moved back to the left.
  • Ross Slater
    edited May 2020
    Hi I tried what you said and it does go back to the left but as soon as I transmit it's right back to the center again.
    I did not try to transmit. I guess it tries to center your to frequency. Dave wo2x
  • Ross Slater
    edited May 2020
    I read a suggestion to use B slice and set it t same frequency as A then I can move the slice where i want it. Thanks for your input.
