no receive audio
WA6HTP - Juan Rivera
6700, local control, SmartSDR 2.6.1 upgrade. Worked fine for years until I upgraded SmartSDR slightly and switched to another PC. Can't go back to old PC without reverting the firmware. No receive audio anymore. Icon in upper right is on and speaker gain is up. DAX-1 selected everywhere . DAX Slice-A shows audio in meter. Device Manager / Audio in/out shows usual huge list of Flex I/O. RX-1 look normal. What am I missing?
Are you using the radio with PC Audio or Computer Powered speakers plugged into the Radio?
I would do a HARD RESET and see if your audio returns.
Bret
You need to use the computer default audio device. You don't use dax.0
Thanks guys! I knew I was doing something dumb. Problem solved!
73, Juan - WA6HTP0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
