Is it possible to align slice to the left Flex 6400m front panel?
Ross Slater
When using a DIGU 3.5 band width as an example is it possible to keep the slice aligned to the left instead of the middle?
You can move the slice to the left side by putting your finger on the panadapter to the right of the passband and drag to the left.
I saved it as a global profile, shut down the Maestro and restarted. The slice remained in the last position (to the left). I moved the slice to the right then loaded in the global profile I had just saved with the slice to the left. The slice moved back to the left.
Hi I tried what you said and it does go back to the left but as soon as I transmit it's right back to the center again.
I did not try to transmit. I guess it tries to center your to frequency. Dave wo2x0
I read a suggestion to use B slice and set it t same frequency as A then I can move the slice where i want it. Thanks for your input.
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
