Remote Start since the new firmware
W7NIK
My system is 6500 v3.1.11 Kamtronics UDP 8 relay board with a RCA cable.
Lan cable into the network
On the first start up it 50/50 shot flashing green or solid green.
If i try again it shuts down then i try it again, most of the time i get solid green.
Why is this happening since the firmware up date ?
I am using thin wire for the remote RCA plug, maybe better wire?
Am i the only one have this problem ?
I did factory reset already and loaded my profiles.
i had no problems for months .
I keep it on 8 hr at a time.
- Radio setup menu has the Remote enabled
Try disabling your remote start up and see if it still does this. It sounds as if your remote switch is likely to be the problem and this is an easy way to find out. The remote switch does not draw a great deal of current but if your RCA cable was really thin its resistance might cause the Flex to have insufficient voltage to reliably engage.
Same exact problem with my 6500. Started with the update to 3.1.11.
It seems to be happening more frequently now.
Have to hold in the power button for 5 sec to turn it off once in the fast-blinking green light.
Will open a help desk ticket.0 -
WELL its getting worst !
6 times remote on remote off, push button , disconnected power, still can't boot!
Finally after 7 times i got it to work , going back a version.0 -
I would not recommend going back a version! Beware the release notes state the following:
Release Specific Caveats:
After installing this release (v3.1.11) we strongly recommend you do not revert to a
previous version of SmartSDR to ensure the data integrity of the SD card.
If you do let us know how it goes?
Cal/N3CAL
My 6700 works fine for remote on and off with the new update, I can't check the F6600M because I lost the SDCard and waiting for the new one to come in before I can test that one.
Bret
What SD card , I guess there a Sd card in the box ? So never shut it off , ? Or pack it up and send it in ?0
it's on the 6400 and 6600 model, I don't think the other models have the issue at least I have never lost one on them on my old 6700. This is one of the MAIN fix's on the NEW firmware that was just released to stop this from happening according to the release notes so don't think it pertains to your 6500.0
Those of you that are having this problem: Do you have any kind of 3rd party application or hardware (Antenna Genius, etc) running that connects to the radio as soon as it boots up?0
W7NIK, yes all 6000 radios have an SD card . there have been SD card problems reported on all models but it is not a common problem and has not effected everyone. Flex made changes in software in the last maintenance up date to protect the cards better.1
yes i do been running fine for months, Pst rotator AZ controls my relays, Relay 8 turns on my 6500 , then when it finally starts the other automatic relays click in , based on freq, 80 m switches relays etc.0
But the PST works thru the CAT port 4992 after startup is solid green .0
thank you i did not know , thought it was aftermarket SD cards0
The cards are not the type you buy in a store, the ones Flex uses are very heavy duty and can be writen to thousands of time more than the consumer brands.0
I don't think something connected via CAT should cause this. We have identified an issue that is present in both v3.1.8 and v3.1.11 that can cause the radio firmware to crash if a client connects while we are in the final stage of booting up. We have a fix coming for this, but in the meantime, if you are using an application or hardware that connects automatically to the radio via the API (not CAT), you can work around this issue by booting the radio without the application or hardware running. Once the radio is booted up, it should be fine to start the application and/or hardware without a problem.1
Ok, I opened a Help Desk issue, Ken has helped me correct the problem. Here it is:
6) Try this Cold-Boot Factory-Reset procedure, even if you have done something similar before. This has some specific timing elements that make sure that the processors are reset properly.
Back up your profiles
Note: If you skip this step, you will delete any saved profiles. If you have not created any profiles, this step is not necessary.- Start SmartSDR for Windows and connect to your radio
- Export your Profiles with the Preferences setting UNSELECTED. << important!
- Close SmartSDR
Perform a Cold Boot and Factory Reset of your radio- Power off the radio by pressing and releasing the power button. Allow it to completely power down before continuing by waiting for the power LED to turn off (or amber if a GPSDO is installed). If pressing and releasing the power button does not shut down the radio, press and hold the power button until the radio shuts down.
- Once the radio is powered off, wait for 2 minutes to allow for all processors to properly shut down.
- Remove the power cable from the radio for at least 30 seconds and then reconnect it. It is important to remove the power cable from the radio and not just turn off the power supply.
- After reconnecting the DC power cable, wait for 2 minutes to allow for the internal PSoC processor to boot up completely before continuing.
- Press and hold the OK button while pressing and releasing the Power button.
- Release the OK button once the power LED turns white and allow the radio to continue booting normally.
This solve my problem with node red while booting radio crashes and flashing red!!
Question; What is the "OK" button you say to hold while pressing and releasing the Power button?0
Alan, on the 6500, 6700, 6300, there is an ok button in the centre of the multi button on the front.0
Great to learn Eric, you have identified the issue that causes the radio to crash on boot up if a client connects when the radio is in final stages of boot up. I do this all the time with my windows laptop and/or ipad connecting before the radio has booted. The radio is to one side of me out of sight and I think what happens on boot up is I hear the fan running and think it has completed the boot but it has not completed and crashes as my client connects :-(0
I did this procedure, I did get one good boot , first remote signal it went solid green
! Then I tried it again not good flashing green . If I do a 5 sec button reset it reboot Ok . Do not shut it down
I would open a HelpDesk ticket and have Ken or someone work through this with you. GL
P.S. I found the instructions must be followed exactly, reset times, etc.0 -
Eric: I have had this problem running 3.1.8 currently.
My radio room is in the garage. I operate "remotely" from a more comfortable
room inside the house. I use Node Red to control relays that power on the radio and connect to read status from the 6600. This sometimes causes a crash while booting up.
Once you have a fix, I would be interested in helpig with beta testing.
Neal Pollack, N6YFM0 -
Well , I think we have a solution
No profiles loaded all works fine . I did 2 button start up , ok , i did maestro connection, then i did 3 remote start ups. all OK . My profiles import has issues.
Customer service at flex is AWESOME !
So how do you do this procedure on a 6600 that does not have an OK button?0
Just press and hold the power button when powering up for a factory reset on models that don't have an OK button. Be warned: This will cause your existing settings to get wiped out. Backup your profiles and preferences prior to doing this if they are important to you.0
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 211 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
