Remove old version on Maesteo
iz7auh
iz7auh Member ✭✭✭
edited May 2020 in Maestro
How to remove all old version of SmartSDR on maestro? image
  • G4NRT
    G4NRT Member ✭✭
    edited May 2020
    Following!
    edited May 2020
    Hi Frank
    You can't.
    Flex engineering actually controls what you see in the pic list.  They will clean that up at some point in the future, so you will have to wait a bit.  We are aware of what you see.
    All those versions are NOT installed on your Maestro, so they are not taking up any space at all.  If you were to change versions, then the Maestro would download the version you wish from the online servers.
    73 for now, Mike va3mw
  • VA7BNB_Brent
    VA7BNB_Brent Member ✭✭
    edited May 2020
    Hello Mike and all,
    Thanks for the response, I wanted to clean up that list in my Maestro  too.
    ...Brent...
    "Be calm, be safe, be kind, be safe"
    edited May 2020
    Hi Brent
    The list is controlled by Flex Radio engineering.  They will clean it up at some time in the future.
