RXAssistant Version 2.4 Now Available
NOTE! 2.4 FIXES A DIVERSITY CONNECT PROBLEM ASSOCIATED WITH THE 6600M RADIOS ONLY..
I wrote this program to provide quick point and click selection of Receive
Antenna's and other receive options and to avoid some of the Touch Screen
fumbling associated with the Maestro or Menu's in it and SmartSDR.
Each Antenna can be selected manually using the Buttons so named.
Audio can be switched between headphone or Speakers.
Binaural Audio can be turned on or off.
Diversity Receive can be activated and Right and Left Antenna's selected.
RF Gain can quickly be changed to optimize Antenna gain.
In an environment where more than one Flex is available your Radio
can be selected from a list on the left by Double Clicking the Radio IP.
The Nickname of the radio is show for future reference.
Only Slice A and/or B is controlled. When using One Slice or Two Slices.
As in SO1R or SO2R (two panadapters) .
The A1/A Button will cycle between ANT1 and RXA on Slice A.
The A2/B Button will cycle between ANT2 and RXB on Slice B.
These two buttons can also be activated by HOT Keys [ and ] respectively.
The Hot Keys will continue to be active even if the Program window is minimized. The Hot Key function will NOT take Focus from Logging Programs.
I Wrote the Program for Myself and a few friends with special requests.
I Hope it might be useful to some others... Enjoy
It is available on our Club Web Site at http://www.w9az.com
It is in a standard Zip File and Instructions along with a PDF are also available
on the Web Site..
I can be contacted at kenbuser at gmail.com
NOTE! 2.4 FIXES A DIVERSITY CONNECT ASSOCIATED WITH THE
6600M RADIOS.
73's Ken W9IE
Very nice
Have not seen before...but it looks very good.
Works great Nice work Ken.
https://www.w9az.com/
Diversity receive available to the 6600, 6600M and 6700 models only with two SCU's.
Nice Tool, working fine here. could you integrate XVTA as antenna input also in the next release, tnx Alexander, DL5VZ1
In case you missed this
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
