API Help
K1ESE
Member ✭✭✭
I want to access the API to turn a relay output off and on.
This works -
ampline$ = "tx1"
handle = TCPOpen(radioaddress$, 4992)
temp =TCPPrint(handle, "C0|interlock "; ampline$; "_enabled=f")
It turns off.
This doesn't -
ampline$ = "tx1"
It doesn't turn back on.
Please, what did I mess up?
K1ESE
This works -
ampline$ = "tx1"
It turns off.
This doesn't -
ampline$ = "tx1"
K1ESE
Did you mean to say "_enabled=t" (true) in the second snippet?
Not an expert on the FlexAPI but your two sample code fragments, as written here are identical. If that's what you really have, then I suspect you need to change "_enabled=f" to "_enabled=t".
Yes, I copied wrong from the program.
This doesn't work -
temp =TCPPrint(handle, "C3|interlock "; ampline$; "_enabled=t")
I'm guessing I have messed up the syntax somehow.
Do you issue commands C1 and C2 before issuing the C3 that doesn't work? There may be something going wrong in the intermediate code that you've not shown. Do you close the TCP/IP connection after each command?
As long as you asked...
Liberty Basic Code -
' TCP/IP socket functions by by Alex Davies
open "mesock32.dll" for dll as #me
[setup.main.Window]
nomainwin
WindowWidth = 200
WindowHeight = 146
UpperLeftX=500
UpperLeftY=200
loadbmp "Tune", "C:Tune Antenna Tuner SafelyTune.bmp"
loadbmp "Stop", "C:Tune Antenna Tuner SafelyStop.bmp"
'-----Begin GUI objects code
bmpbutton #main.start,"C:Tune Antenna Tuner SafelyTune.bmp",[startClick], UL, 0, 0
'button #main.reconn, " RESET ", [reconnClick], UL, 0, 76 , 184, 30
'-----End GUI objects code
open "TS" for window as #main
'print #main.reconn, "!font ms_sans_serif 14 bold"
print #main, "trapclose [quit]"
'read .ini file for address, RCA TX line, tune power
open "C:Tune Antenna Tuner SafelyTATS.ini" for input as #tuncfg
line input #tuncfg, radioaddress$
line input #tuncfg, ampline$
input #tuncfg, tunepower$
close #tuncfg
tuneflag=0
' handle = TCPOpen(radioaddress$, 4992)
' temp =TCPPrint(handle, "C4|transmit set tunepower=0")
[main.inputLoop]
wait
[startClick]
if tuneflag = 0 then
'temp =TCPPrint(handle, "C1|transmit set tunepower=";tunepower$)
temp =TCPPrint(handle, "C1|transmit tune on")
print #main.start, "bitmap Stop"
tuneflag=1
else
temp =TCPPrint(handle, "C2|transmit tune off")
'temp =TCPPrint(handle, "C4|transmit set tunepower=";tunepower$)
temp =TCPPrint(handle, "C3|interlock "; ampline$; "_enabled=T")
temp = TCPClose(handle)
print #main.start, "bitmap Tune"
tuneflag=0
end if
wait
'[reconnClick]
' temp = TCPClose(handle)
' wait
[quit]
close #me
close #main
end
''''Function TCPOpen()''''''''''
Function TCPOpen(address$,Port)
Timeout=1000
calldll #me, "Open", address$ As ptr,_
Port As Long,_
Timeout As Long, re As Long
TCPOpen=re
End Function
''''Function TCPReceive$()''''''''''
Function TCPReceive$(handle)
buffer=4096
all=0
calldll #me, "ReceiveA" ,handle As Long,_
buffer As Long,_
all As Long, re As long
if re<>0 then TCPReceive$ = winstring(re)
End Function
''''Function TCPPrint()''''''''''
Function TCPPrint(handle,text$)
calldll #me, "PrintA", handle As Long,_
text$ As ptr,re As Long
TCPPrint=re
End Function
''''Function TCPClose()''''''''''
Function TCPClose(handle)
calldll #me, "CloseA",handle As Long,_
TCPClose As Long
End Function
Is the issue that you used a capital "T" instead of lower case "t"? 73, Len, KD0RC0
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
