N1MM Voice Keyer
I just worked out the answers to some of Paul's questions and wanted to post them for the next ham trying to use the Voice Keyer with SmartSDR.
First set up audio To and From N1MM+ under Config>Logger+ Audio Setup. Playback tab should have DAX Audio TX selected under Radio 1 and Message Recording tab should have DAX MIC Audio under Radio 1.
To Record on the Fly: begin transmitting, then press CTRL+SHFT+F# key to begin recording for the selected F# key. Record your desired message, then press ESC key to end the recording and save the .wav file. Stop transmitting at this point.
Some additional notes:
- Recordings will be different depending on if you are in Run or S&P in N1MM+.
- In the CAT window, make sure a COM port is designated for N1MM. Make sure that same COM port is set in N1MM under Config>Configure Ports.... .
- In the DAX window, make sure TX stream is on.
- Make sure DAX is selected in SmartSDR
N1MM+ .wav files for voice keyer are located in folder location Documents\N1MM Logger+\Wav\{operator} where the {operator} is the callsign of the operator designated at N1MM at that time.
This solution worked with SmartSDR v3.6.8 and N1MM+ 1.0.10180.
Ben KN4RFT1
In N1MM+ "Config" menu, choose "Logger+ Audio Setup". In this dialog, click the "Playback" tab, then in the drop-down under Radio 1, select "DAX Audio TX (FlexRadio Systems)". Then in SmartSDR, in the "PHNE" control panel, click the "DAX" button. It will turn blue to indicate it is active. You will also need to define a PTT port in SmartSDR CAT, and connect N1MM+ to that. You can use either a foot switch or VOX for live voice with your radio Mic. It all works very smoothly.
73,Craig, KØCF
Thanks Craig, got the N1MM voice keyer working now.0
Yes thanks for putting us on the fast track. This is on my to do list.0
Just using this feature now with the Florida QSO party, Craig got me right to the answer.
Thanks.
Craig - hope you don't mind resurrecting an old thread, but I not making it to first base on the N1MM Voice keyer challenge. In a May 18 post you listed:
In N1MM+ "Config" menu, choose "Logger+ Audio Setup". In this dialog, click the "Playback" tab, then in the drop-down under Radio 1, select "DAX Audio TX (FlexRadio Systems)"== DONE
. Then in SmartSDR, in the "PHNE" control panel, click the "DAX" button. It will turn blue to indicate it is active. == DONE
You will also need to define a PTT port in SmartSDR CAT, and connect N1MM+ to that. You can use either a foot switch or VOX for live voice with your radio Mic==== ALSO DONE
*** in the N1MM Audio Setup & Monitor , when I do the Test in the Monitor tab, I see green bars in the wav and output columns. In the Message Recording tab I selected DAX Mic Audio.
*** But then I am lost, don't see how to actually record a msg ? Where does it get stored and how do I link to an Function Key??
73 & tnx Paul
w2eck
- 372 Community Topics
- 100 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 939 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 999 Third-Party Software
