Keyboard CW (K1EL K44 CW Keyboard and Reader Kit)
John - ZL3TRR
Before I get comments re I should learn Morse by ear, I wish to state I have a hearing problem and wear two hearing aids and want to try CW.
I have a K1EL K44 CW Keyboard and reader Kit which I want to connect to a Flex 6500.
Has anyone done this before or can offer a Keyboard CW option with the Flex 6500?
It must be able to send and read .
Help would be appreciated . 73
Hi John, if you are running SmartSDR, there is a CWX feature that allows you to use your keyboard to send CW. CW Skimmer can be purchased and installed which will do the decoding. I know that does not utilize the K44, but it is an option that just requires a bit more software.
Len, KD0RC
Hi Len, Thanks for the Information and I will have a look at that. Keep safe 73 John0
Hi John,
I have K44 and it works well with my 6700. It's a little annoying in that the K44 will not work directly with a USB keyboard. You will need an adapter. Otherwise, no problems.
Rick, WC8D
FRLogger has a great CW keyboard and now has a built in CW decoder that works pretty well. Give it a try. It's free and easy to use. http://ws7m.net/index.php/logger0
Thanks Joe, The decoder will improve from what it is now.0
Thank you Joe and Mark. I will give FRLogger a try 73 John0
Yes I found his interesting website previously . I like . 73 and keep safe. John0
Rick, What cables go where to flex ? and what settings in smart sdr ?
look forward to reply or you can contact me direct via QRZ.com 73 John0 -
> @"Rick - WC8D" said:
> Hi John,I have K44 and it works well with my 6700. It's a little annoying in that the K44 will not work directly with a USB keyboard. You will need an adapter. Otherwise, no problems.Rick, WC8D
Hi Rick, could you please provide instructions how to connect the K44 with the Flex Radio 6700? What kind adapter will one need?
Thank you, 73, Alex AK1MD0 -
I am interested finding out how to connect a K44 CW reader with the Flex Radio 6700?
Appreciate any help.
+1 for CW Skimmer. It works well providing the sender has a good fist and sending good spacing. I do agree you should learn CW since nothing decodes as good as the human brain but CW Skimmer will help you to confirm what you think you hear.
For sending I use CWX built into SmartSDR or N1MM+ macros for contests. CWX has a live mode which allows keyboard CW.
Where are you providng audio to the K44?
Don - kx9q
[{"insert":"I tap it off the audio out before it goes to my Bose powered speakers. \n"}]0
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
