CWX special characters
Tore Andersson
I just found out - first time I had a qso in swedish language that CWX does not support the swedish special chacters. Is there any way to "teach" it to the radio ?
Same problem here. Should be very easy to implement. Just add ä,ö,å and you make all scandinavian flex users (both) happy
You can find the ascii codes for those easily or send me the source code and I will add those. 0 -
One very easy way to implement this is to make a table for characters outside z that allow to edit in smartsdr and then load it. Such a table must exist internally in the software anyway ? in order to translate each characters to dot and dashes some translation must occur. In this way you dont have to know the characters in flex. Much like the turf file1
my guess is
maybe when winkeyer support character sets other than ASCII
need to remember that flex uses winkeyer command /character set
then
cwx could be updated...
till then
my guess...it aint that 'easy'
as that would break lotta third paty logging and contest and cw s/w
that uses winkeyer standard
Paul K3SF
FRLogger has a CWX panel that transmits CW characters to the CWX interface in the Flex Radio API.
I have not tried special characters but I have played around with sending strange stuff to the interface to see what happens and in most cases nothing happens.
I think the idea of some table is a good one. Or perhaps even better an API that would allow for loading the CW table in from external apps like FRLogger and some of the other CW external apps.0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
