CWX special characters
I just found out - first time I had a qso in swedish language that CWX does not support the swedish special chacters. Is there any way to "teach" it to the radio ?
  • Mika Rintala
    Mika Rintala Member ✭✭
    edited April 2020
    Same problem here. Should be very easy to implement. Just add ä,ö,å and you make all scandinavian flex users (both) happy :) You can find the ascii codes for those easily or send me the source code and I will add those.
  • Tore Andersson
    edited April 2020
    One very easy way to implement this is to make a table for characters outside z that allow to edit in smartsdr and then load it. Such a table must exist internally in the software anyway ? in order to translate each characters to dot and dashes some translation must occur. In this way you dont have to know the characters in flex. Much like the turf file
  • K3SF
    K3SF Member ✭✭✭
    edited April 2020
    my guess is
    maybe when winkeyer support character sets other than ASCII
    need to remember that flex uses winkeyer command /character set
    then
    cwx could be updated...
    till then
    my guess...it aint that 'easy'
    as that would break lotta third paty logging and contest and cw s/w
    that uses winkeyer standard
    Paul K3SF
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited April 2020
    FRLogger has a CWX panel that transmits CW characters to the CWX interface in the Flex Radio API.
    I have not tried special characters but I have played around with sending strange stuff to the interface to see what happens and in most cases nothing happens.
    I think the idea of some table is a good one.  Or perhaps even better an API that would allow for loading the CW table in from external apps like FRLogger and some of the other CW external apps.
