No CAT, no DAX?
ON5AM
ON5AM Member ✭✭
Hello Community,
a week ago, turning on my flex, I no longer had a CAT port. I tried everything then I erased everything and reinstalled everything at least 10 times.
I note that the "Flex VSP" drivers are not installed. It's impossible to install them manually.
It's impossible to install DAX, even with Tim's trick. I am confused.
I opened a tiket last Friday but I don't have any help and that's why that's I'm asking to the Flex community. Do you have a solution ?
Albert ON5AM
  • Jean_Luc F5JRC
    Jean_Luc F5JRC Member ✭✭
    edited May 2020
    Hi Albert,
    I had the same issue several months ago.
    I follow this: https://helpdesk.flexradio.com/hc/en-us/articles/205000829-Troubleshooting-FlexVSP-Not-Running-Errors
    In fact the Virtual Serial Port Kit service was not running.
     You can see informations how to fix this issue at the end post.
    It solves my problem here.
    Just in case you find it useful!
    73 Jean-Luc
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited April 2020
    Likely your system did a Win10 update.  The latest updates breaks some installations, but not all.
    Jean-Luc's post covers the first bases towards repairing things.
    As an FYI if you are using certain VPN clients, the latest Windows updates also often upset that software.  Again usually a App>Repair or a more invasive Uninstall/Reinstall often fixes things.
    If you have complicated profiles remember to export them before uninstalling or reinstalling SmartSDR itself.  Just in case.
    One of my Win10 machines required multiple rebooting before it would work right.  I also used the SmartSDR installer as the manual method of reinstalling FlexVSP didn't take.
    GL and 73
    Steve
    K9ZW
    Blog:  http://k9zw.wordpress.com
  • on5po
    on5po Member ✭✭
    edited April 2020
    Hello, for my part, since the last update of windows of 21 04 20, impossible to open, the post CAT
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited April 2020
    Do you have the cat and dax utility program installed. This is a little program that saves dax and cat settings, then you just use it to put all the settings back just like you want them.
  • on5po
    on5po Member ✭✭
    edited April 2020
    Bonjour Bill,
    oui, DAX est présent
  • WK2Y
    WK2Y Member ✭✭
    edited April 2020
    That sounds very handy.  Do you know the program name and where to find it?
    Thanks!
    73, Bob
  • on5po
    on5po Member ✭✭
    edited April 2020
  • WK2Y
    WK2Y Member ✭✭
    edited April 2020
    This is going to save a lot of grief.  Thank you!!
  • on5po
    on5po Member ✭✭
    edited April 2020
    After removing and resuming smartsdr, for the second time everything is in order again
  • ON5AM
    ON5AM Member ✭✭
    edited April 2020
    I found!
    The problem came from updating windows. Everything works as before, unfortunately I had to reset Window 10. I lost a lot of things but smartSDR works...
    One last thing: the Flexradio help desk din't help me, it was not at all reliable!
  • Bill -VA3WTB
    edited April 2020
    Make sure you download and install the little file manager utility I post here, it can save you in the future if you have another rainy day.
