No CAT, no DAX?
ON5AM
Hello Community,
a week ago, turning on my flex, I no longer had a CAT port. I tried everything then I erased everything and reinstalled everything at least 10 times.
I note that the "Flex VSP" drivers are not installed. It's impossible to install them manually.
It's impossible to install DAX, even with Tim's trick. I am confused.
I opened a tiket last Friday but I don't have any help and that's why that's I'm asking to the Flex community. Do you have a solution ?
Albert ON5AM
Albert ON5AM
Hi Albert,
I had the same issue several months ago.
I follow this: https://helpdesk.flexradio.com/hc/en-us/articles/205000829-Troubleshooting-FlexVSP-Not-Running-Errors
In fact the Virtual Serial Port Kit service was not running.
You can see informations how to fix this issue at the end post.
It solves my problem here.
Just in case you find it useful!
73 Jean-Luc0 -
Likely your system did a Win10 update. The latest updates breaks some installations, but not all.
Jean-Luc's post covers the first bases towards repairing things.
As an FYI if you are using certain VPN clients, the latest Windows updates also often upset that software. Again usually a App>Repair or a more invasive Uninstall/Reinstall often fixes things.
If you have complicated profiles remember to export them before uninstalling or reinstalling SmartSDR itself. Just in case.
One of my Win10 machines required multiple rebooting before it would work right. I also used the SmartSDR installer as the manual method of reinstalling FlexVSP didn't take.
GL and 73
Steve
K9ZW
Blog: http://k9zw.wordpress.com
Hello, for my part, since the last update of windows of 21 04 20, impossible to open, the post CAT
730 -
Do you have the cat and dax utility program installed. This is a little program that saves dax and cat settings, then you just use it to put all the settings back just like you want them.0
Bonjour Bill,
oui, DAX est présent
730 -
That sounds very handy. Do you know the program name and where to find it?
Thanks!
73, Bob0 -
This is going to save a lot of grief. Thank you!!0
After removing and resuming smartsdr, for the second time everything is in order again
730 -
I found!
The problem came from updating windows. Everything works as before, unfortunately I had to reset Window 10. I lost a lot of things but smartSDR works...
One last thing: the Flexradio help desk din't help me, it was not at all reliable!
Make sure you download and install the little file manager utility I post here, it can save you in the future if you have another rainy day.0
