HEIL HM-12M CC-1-K (Red end) and Heil FS3 Foot Switch
Santiago Mejia HI8O
Santiago Mejia HI8O Member ✭✭
I just got a Heil HM-12 mic (new) and a XLR to 8pin Cable (CC-1-K, red end, with PTT connector) and already had a Heil FS-3.
I'm trying to connect everything but I get no response from the MIC in the radio nor the ptt. Am I missing something or is the cable the wrong one?
73, Santiago
  • Bob K8RC
    Bob K8RC Member ✭✭✭
    edited April 2020
    Wrong adapter.
    You need a CC-1-Y (Yaesu)
    It's wired differently.
  • Santiago Mejia HI8O
    edited April 2020
    Ok. Let me look for one. Thanks Bob.
  • FISHULA X
    FISHULA X Member ✭✭
    edited April 2020
     You need the one with the orange boot if your referring to a Heil cable?.  Flex uses the same wiring as Yaesu. Or, you can just rewire the 8 pin Foster plug.
  • Ken Hansen
    Ken Hansen Member ✭✭
    edited April 2020
    Yes, wrong adapter - red is kenwood, blue is Icom, yellow/orange is Yaesu - the Zflex radios are wired like Yaesu radios, so the yellow/orange adapter is correct.
    edited April 2020
    Thanks. Will get to the rewire process.
    edited April 2020
    Does anyone has a side to side comparison on both wiring?, I remember seeing one in another post but cant find it now.
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    Look at Yaesu Mic wiring it is close other then the chassis ground and MIC ground
    https://community.flexradio.com/flexradio/topics/how_is_the_flex_6000_front_panel_microphone_connector_pinned_out
    TOOK exactly 2 seconds to find the above link using Google search (Google search is your friend)
    73's
    Bret
    WX7Y
    edited April 2020
    Thanks Brett. I will next time.
    73.
  • Ken Hansen
    edited April 2020
    "TOOK exactly 2 seconds to find the above link using Google search (Google search is your friend)" There was probably a better way to make that point. "I remember seeing one in another post but cant find it now." Santiago searched, but didn't find it - he said as much when he posed the question.
  • FISHULA X
    FISHULA X Member ✭✭
    edited April 2020
    edited April 2020
    Thanks Ken.
    edited April 2020
    Thanks.
    edited May 2020
    To update you on this, I just rewired the cable (as suggested) to the Yaesu/Flex pin outs and the cable is now working fine. Saved me the costs of the new cable. Thanks everybody for the help.
    73, de Santiago, HI8SMX
