HEIL HM-12M CC-1-K (Red end) and Heil FS3 Foot Switch
Santiago Mejia HI8O
I just got a Heil HM-12 mic (new) and a XLR to 8pin Cable (CC-1-K, red end, with PTT connector) and already had a Heil FS-3.
I'm trying to connect everything but I get no response from the MIC in the radio nor the ptt. Am I missing something or is the cable the wrong one?
73, Santiago
73, Santiago
Wrong adapter.
You need a CC-1-Y (Yaesu)
It's wired differently.
Ok. Let me look for one. Thanks Bob.0
You need the one with the orange boot if your referring to a Heil cable?. Flex uses the same wiring as Yaesu. Or, you can just rewire the 8 pin Foster plug.1
Yes, wrong adapter - red is kenwood, blue is Icom, yellow/orange is Yaesu - the Zflex radios are wired like Yaesu radios, so the yellow/orange adapter is correct.1
Thanks. Will get to the rewire process.0
Does anyone has a side to side comparison on both wiring?, I remember seeing one in another post but cant find it now.0
Look at Yaesu Mic wiring it is close other then the chassis ground and MIC ground
https://community.flexradio.com/flexradio/topics/how_is_the_flex_6000_front_panel_microphone_connector_pinned_out
TOOK exactly 2 seconds to find the above link using Google search (Google search is your friend)
73's
Bret
WX7Y
Thanks Brett. I will next time.
73.0 -
"TOOK exactly 2 seconds to find the above link using Google search (Google search is your friend)" There was probably a better way to make that point. "I remember seeing one in another post but cant find it now." Santiago searched, but didn't find it - he said as much when he posed the question.1
Thanks Ken.0
Thanks.0
To update you on this, I just rewired the cable (as suggested) to the Yaesu/Flex pin outs and the cable is now working fine. Saved me the costs of the new cable. Thanks everybody for the help.
73, de Santiago, HI8SMX1
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
