DLI Web Power Switch, need example SW, web, or GUI?
Neal Pollack AB6G
For remote control of the station, I know that some of you are using the DLI Web Power Switch with 8 outlets. I just got one and am starting to study the software API.
Does anyone have an example GUI, or HTML web page, Python, or any other software code example, where you created buttons to control the power outlet and color code if it is ON or OFF?
I am only an average programmer, and find I have a much easier time modifying an example for
my needs, rather than starting from a blank page.
Cheers,
Neal, N6YFM
Cheers,
Neal, N6YFM
Not sure why you need to program anything on the DLI switch's they have great WEB page that all you have to do is edit the names,
The Macro's do need to be written that allows you to turn power outlets off and on with timers.
I have about 100 of these switch's at work and on our large repeater systems
there is a Android app that someone wrote a long time ago that lets you control them remotely if you have the IP Port open on your network.
73's
Bret0 -
Suggest you look over the below Flex Community Discussion for ideas. Like you prefer, I have expanded upon many of the examples given for my remote station operation. I use Raspberry Pi's at the station to control many device functions, connect to the Flex USB cable functions, and to input environmental (temperature, volts, amps) data.
All of the above are accessible on custom user interfaces via local or remote web browsers.
https://community.flexradio.com/flexradio/topics/remote-operating-and-node-red
Alan
WAWUD0 -
I can supply Node Red flow for my DLI Web Switch Pro.
Dave wo2x0 -
That would be educational and most appreaciated.
Info good on QRZ.com and also email N6YFM@ARRL.net
Thanks Dave.
Neal, N6YFM0 -
You can also control this from linux using a script they supply. Very easy. Let me know if that is of interest.0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
