Mic 2 input seems way to low, or not working on Maestro
I have been using my Maestro with my 6300 and have been doing a LOT of listening, and in receive it seems to work just great, and it works will with the built in tuner in the 6300. Just recently I have been getting more active on the air and tried to make an adapter to work with my Yamaha CM500, but when I try it, even with the +20db boost, I get very LOW modulation. My 6600M came with a FHM-2 hand mic and I tried it in the mic 2 input and used the MOX to key the radio, and I go NO modulation with that mic. When I use my 6300 with my CM500 on my computer with the SmartSDR software, it all works great. I tried the FHM-2 mic on the 6600M and it works great. Does the Mic 2 input have a problem on my Maestro, or am I doing something wrong?
Don - KD7CI
Don - KD7CI
Double check everything; mic gain, Mic2, Bias on , +20dB, etc and check that the mic and phones plugs are no crossed.0
Things checked:
Mic Bias - ON
+20 DB - ON
Mic Gain - MAX position
Mic plugged into 3.5mm MIC2 Jack on Maestro
Headphone plugged into 3.5mm headphone jack on Maestro (and the headphones work just fine, I can hear what ever I need to hear)
Still no joy... same outcome as previously stated
Don
The FHM-2 mic doesn't work properly with the Maestro. Open a HelpDesk ticket to see what options are available.1
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
