Zoom Window
I would love to see a configurable spectrum zoom window that would show 5 KHz or so around the current slice freq and be sizable and perhaps dockable. A default of a couple inches wide by an inch high would be a good starting point. This would allow more precise tuning, and would especially help the positioning of TNF notches. It would be great to have it clickable like the main panadapter for tuning. Best solution would allow it to be spectrum, waterfall or both. SDRPlay and other SDR software currently have this feature.
Another thing that would be nice is an addition to the floating window that shows cursor position frequency. How about having it show dBm and signal strength (S0 - S9 +40) as well as frequency?
Thanks for your consideration.
Len, KD0RC
Len, KD0RC
Right-click on the spectrum display and select "Tune Guides". This puts a vertical line at the mouse and displays the frequency where it is positioned.
You can zoom in and out on the spectrum display, enough to easily display fine details in the signals. Use the zoom controls in the bottom left corner of the display.
Yep, I get all that. I would like a pre-zoomed window surrounding the active slice that does not require playing with, so that notches, filter adjustments and fine tuning can happen very quickly.
I have the tune guides set, and I do see the freq, but I would also like to see the cursor dBm and sig strength. I think this would be a relatively easy add to the functionality.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
