DAX problem with wsjt-x
Al / K1LTJ
AL,
You didn't say which version of (DAX) SSDR you have installed on your PC. SSDR Versions 1.12.1, 2.6.1 and 3.1.8 where released specifically to eliminate the DAX naming issues. These versions contain the DAX 3.1.0.5 drivers and are available at no charge for you licensed major version. If you wish, you may just install the new SSDR version ( which contains the new DAX drivers) on your PC without up grading the firmware in you radio. But I recommend up grading the radio also.
AL, K0VM
Thanks Al, I am using 2.5.1, and it has been stable. Perhaps I'll take a shot at 2.6.1. Still, I dont understand why wsjt doesn't seem to read the win10 info correctly.
Al
AL,
The DAX renaming procedure does have a potential trap when deciding what to name what. Its likely that an IQ port got renamed with a non-IQ name and visa versa ( and still look correct in the device manager). You could probably work through the naming process again and find the problem but I recommend the upgrade to 2.6.1 and you should be done with the DAX naming issues. Like I said you can just install 2.6.1 on the PC but still run older version of SSDR on the radio if it is not removed from the PC. 2.6.1 does contain some other bug fixes as well. Look at the change log.
AL, K0VM
I've had an issue with WSJT-X with every update. The Dax Receive stays the same, but the Dax transmit setting in WSJT-X doesn't work.
The whack-a-doodle fix is to change the settings (mono, right-left-both) in WSJT-X until it starts sending audio to DAX. Weird thing is, it is usually the setting used that worked before. Bt it wants me to go through the motions of changing everything, I guess.
Given that all my other programs that use DAX stay the same, like fldigi, I heavily suspect it's a a WSJT-X problem.
I now do a pre-check after every Windows update. I've missed 2 ATNO's when trying to catch DX after an update.
Al, I had the same problem about a year ago. After many days of frustration with DAX, I consulted a fellow Windows IT expert. First of all I don't have any speakers connected to my computer and I'm running Windows 10 latest update. No speakers connected means that Windows has to connect to an audio source, any. It grabs the first DAX port available and creates havoc when you try to use anything that needs DAX. Solution, under $10.00 you can install a USB soundcard to your computer and voila! problem solved. Windows is happy with the soundcard and digital programs can use DAX without frustration. Good Luck0
That is very interesting Bob. I'll try it out
So, after lot's of hassles I have it working better than every. I took your advice Al, and upgraded to 2.6.1, not just the drivers, the whole package. At that point I brought it all up, and still had the same issue. WSJT-x would decode for a few minutes, to perhaps half and hour, and then quit. For lack of any ideas, I completely remove the flex software (using the flex uninstall), and then re-booted and re-installed 2.6.1. It has been working for over 24 hours with no issues. I don't have any idea what was going on, just one of those windows mysteries, but it's nice to have it back. Thank you Bob, Michael, and Al for the great suggestions and help. This is the greatest forum ever.
Al
I am now back to square one. Everything worked for 24 hours without interruption, but now it is back to the bad behavior. I have tried all suggestions received to date, and nothing helps. I noticed a way to tell when it goes into no operation mode. The waterfall display in wsjt-x will suddenly look as though you are looking through a piece of frosted glass. This happens every 4 to 5 minutes. The only way to get it back decoding is to close and re-open DAX. As far as I can tell, everything looks perfect, the devices in wsjt-x, in device manager, and in the audio panels. I have essentially identical installations on my desktop and laptop, and they both behave exactly the same way. They are both running clean installs of 2.6.1 I am out of ideas. Can anyone think of anything else to try?
Al / K1LTJ
I had a similar problem with the WSJT spectrum changing from square spectra to spectra that looked like rounded mounds. I eventually went to Control Panel->Sound and found multiple instances of duplicate DAX devices that were greyed out along with the expected set of DAX devices that were flagged as Ready. I did a right click on each of the greyed out devices and clicked Disable and the problem went away.
On a later boot, I discovered that all of the greyed out DAX devices had disappeared to be replaced with greyed out devices for the audio channel on my monitor. Now I have problems with that audio channel disappearing but it doesn't affect my operating, so I just live with it. (along with lots of PORTCLS.SYS BSODs when I reboot the computer). Clearly the Win 10 Driver group needs to be summarily fired and the Win 10 driver management code for Sound devices rewritten.
This happened on a clean install of Win 10 (I downgraded from Win 7) so I'm confident that there are no Win 7 residuals affecting the system.
Maybe this will help.
Logan, KE7AZ
This is a known issue where long-duration DPCs generated by the PC adversely affect the audio buffers of the DAX driver causing buffer corruption. Stopping and restarting DAX reinitializes the buffers until the next time the corruption occurs.0
I am strugling after 1000 of QSO with a new installation of WSJT my DAX inputs are not recognized, nor is the TX .... anoying! Not sure if this is a Windows 10 issue or a Flex DAX installation, at least in Windows Playback tab I have doulbe drivers for DAX RX1 to RX5, one set saying not connected and the other set saying connected = suspecting a conflict there... same for the DAX IQ. Strange because I did the manual uninstall BAT and install BAT for all type of drivers.0
Hello, this morning, nothing works anymore HRD waterfall, no wsjtx tune, when I first open flex 2.7.6 I have a window that opens, see the first view
there is also a problem with the "DAX" see second view
no wsjtx and jtalert decoding
who would have the solution, this is the first time this has happened to me
thank you
on5po, Janny
Hi Janny, I would start by exporting all profiles, then do a factory reset of the radio and close SmartSDR. After the reset, start SmartSDR and re-import the profiles and see if the problem persists. If the reset does not solve the issue, submit a helpdesk ticket.
EDIT: Sorry, I forgot to mention that you should re-boot your computer before restarting SmartSDR.
Thank you Len, the problem perciste unfortunately, always the same windows,
73, on5po, Janny
I'm sorry to hear that. Best option is to submit a helpdesk ticket. The Flex crew should be able to help you fix this issue.
the solution was, higher in the post, now it works, rest the sound, the flex that still goes through the screen, even with the volume of the flex cut,
73 thank you for your help
on5po, Janny
Great, I am glad you got it working!
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 747 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
