How do I turn off audio on Maestro when transmitting.
Ed Brenner
Ed Brenner Member ✭✭
edited March 2020 in FLEX-6000 Signature Series
I have had this problem before. Where do I go on the menu to turn off the audio on the Maestro so I don't hear my voice when transmitting
  • Steve - K6SRS
    Steve - K6SRS Member ✭✭
    edited March 2020
    In the Maestro Menu (top center) look under audio or transmit (forget exactly where).  You will find a button to turn the Maestro speaker off during transmit.
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited March 2020
    Turn off Mon (Monitor). You can see menu by pressing the mic gain knob .
  • Bill NE1B
    Bill NE1B Member ✭✭✭
    edited March 2020
    Yes, Steven is correct.  It sounds like MON is on which provides sidetone monitoring.  That is OK if you are using a headset and are SSB contesting.  That way you can monitor your computer's wav files (pre-recorded messages).
