How do I turn off audio on Maestro when transmitting.
Ed Brenner
I have had this problem before. Where do I go on the menu to turn off the audio on the Maestro so I don't hear my voice when transmitting
In the Maestro Menu (top center) look under audio or transmit (forget exactly where). You will find a button to turn the Maestro speaker off during transmit.1
Turn off Mon (Monitor). You can see menu by pressing the mic gain knob .2
Yes, Steven is correct. It sounds like MON is on which provides sidetone monitoring. That is OK if you are using a headset and are SSB contesting. That way you can monitor your computer's wav files (pre-recorded messages).0
- 683 The Flea Market
