WSJT-X frequency not tracking SmartSDR
Al Peterson
This used to work before upgrading and I must have missed a setting somewhere. I recently upgraded to Log4OM2 (v: 2.4.0.0), WSJT-X (v: 2.1.2), JTAlert (v: 2.15.11) and SmartSDR (v: 3.1.8). I operate FT8 exclusively and everything is working with the exception of the frequency being updated in WSJT-X. The correct frequency is in the log. I can change bands from WSJT-X and SmartSDR follows properly. If there is a DX operation on a non-standard frequency, I used to be able to change the frequency in SmartSDR and everything would follow.
I'm using SmartCat for the command / control interface and DAX for the audio.
I also can't get JTAlert v2.15.11 to log automatically to Log4OM. Can someone tell me how to setup the UDP ports?0
I found the solution to my problem buried in the Log4OM2 configuration. Change the settings from "hamlib" to "Omnirig" and add a 2nd CAT interface (serial)0
Open the JTAlert settings, find Logging / Log4OM
ADIF msg: 2236 Control: 2241
Go to Log4OM settings, Software Integration / Connections
Add a UDP Inbound ADIF message on port 2236
I have put a ticket in for the same issue, of wsjt not tracking a profile change, but if I change in wsjt, smartsdr follows... issue here it is not every time
Follow the instructions in Log4OM v2 (I am assuming you are using v2) to the letter and then restart all devices turn SmartSDR up first then Log4OM then wsjt-x. I also use JTAlert and it runs very well with all apps seeing the operating frequency and Log4OM logs the complete frequency. I really like v2 and it logs very well including the added features like mapping and rotator control. It controls PSTrotator nicely. Be patient follow the instructions completely.
PS: start JTAlert after wsjt-x...0 -
Exactly!!0
I use Profiles primarily to change bands, frequency, modes. I have had no problems with this. I found that the PC is the most likely culprit in these issues. And more precisely the Registry files in particular. My computer acted inconsistently until I started making sure that the registry ran cleanly. Getting rid of old registry files helps keep the apps happy and consistent. I use “CleanMy PC” to do various PC maintaining functions.0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
