WSJT-X frequency not tracking SmartSDR
Al Peterson
Al Peterson Member ✭✭
edited June 2020 in Third-Party Software
This used to work before upgrading and I must have missed a setting somewhere. I recently upgraded to Log4OM2 (v: 2.4.0.0), WSJT-X (v: 2.1.2), JTAlert (v: 2.15.11) and SmartSDR (v: 3.1.8). I operate FT8 exclusively and everything is working with the exception of the frequency being updated in WSJT-X. The correct frequency is in the log. I can change bands from WSJT-X and SmartSDR follows properly. If there is a DX operation on a non-standard frequency, I used to be able to change the frequency in SmartSDR and everything would follow.
I'm using SmartCat for the command / control interface and DAX for the audio.
  • w5ap
    w5ap Member ✭✭
    edited March 2020
    I also can't get JTAlert v2.15.11 to log automatically to Log4OM. Can someone tell me how to setup the UDP ports?
  • Al Peterson
    I found the solution to my problem buried in the Log4OM2 configuration. Change the settings from "hamlib" to "Omnirig" and add a 2nd CAT interface (serial)
  • Al Peterson
    edited March 2020
    Open the JTAlert settings, find Logging / Log4OM
    ADIF msg: 2236      Control: 2241
    Go to Log4OM settings, Software Integration / Connections
    Add a UDP Inbound ADIF message on port 2236
  • Dave Garber
    Dave Garber Member ✭✭
    I have put a ticket in for the same issue, of wsjt not tracking a profile change, but if I change in wsjt, smartsdr follows...  issue here it is not every time
  • Patrick
    Patrick Member ✭✭✭
    Follow the instructions in Log4OM v2 (I am assuming you are using v2) to the letter and then restart all devices turn SmartSDR up first then Log4OM then wsjt-x.  I also use JTAlert and it runs very well with all apps seeing the operating frequency and Log4OM logs the complete frequency.  I really like v2 and it logs very well including the added features like mapping and rotator control.  It controls PSTrotator nicely.    Be patient follow the instructions completely.
    PS:  start JTAlert after wsjt-x...
  • Patrick
    Patrick Member ✭✭✭
    edited March 2020
    Exactly!!
  • Patrick
    Patrick Member ✭✭✭
    edited March 2020
    I use Profiles primarily to change bands, frequency, modes.  I have had no problems with this.   I found that the PC is the most likely culprit in these issues.  And more precisely the Registry files in particular.  My computer acted inconsistently until I started making sure that the registry ran cleanly.  Getting rid of old registry files helps keep the apps happy and consistent.  I use “CleanMy PC” to do various PC maintaining functions.
