Gridtracker with Flex 6300 and Multiple Slices
Have anyone is using the combination of multiple slices/instances of WSJTX with Gridtracker and Log4OM v2?
Santiago
Yes, I have them working together with the exception of JTAlert, as ii I don't use it - no need. I am busy today and tomorrow, but will write up how to do it on Sunday.
I am a great fan of GridTracker a superb program for digital modes.
73 Andy F5VAI0 -
Thanks Andy, no hurry here. Really looking forward, because I´ve heard a lot of parises about GridTracker.
73, Santiago
Apologies Santiago for the delay.
So I have a Flex 6300 working with LOG4OM V2, WSJT- X V2.1.2, and GridTracker V1.20.0302.
WSJT- X:
UDP Server 127.0.0.1 Port 2333 All boxes ticked.
Secondary UDP server 127.0.0.1 Port 2237
LOG4OM V2:
Settings/Connections: [UDP_Inbound] [JT Message] [2238] Grid Tracker Call
[UDP_Inbound [ADF_Message] [2236] [GridTracker)
GridTracker:
Settings/General: Receive UDP Messages - Port 2333
Forward UDP Messages - 127.0.0.1 Port 2238 Tick Enabled
Everything works as it should in all three programmes.
Good luck.
73 Andy F5VAI
Thanks Andy. We´ll keep this conversation on the other reflector, which is more related to Gridtracker then Flex.
Santiago
I know that I'm a little late to the party here... It seems that we're using the same hardware and software, Santiago. I have everything working on once slice... apparently the second one is just a matter of addressing it in SliceMaster. In fact, my biggest problem is keeping Slice A as the primary. It kept wanting to chose Slice B until I got everything set. The key is getting all the ports assigned.
Let me know if you want to take a look at how my settings are configured.
Steve, W6SDM
Hi Steve, thanks. I managed to get everything working fine with GT, WSJTX and Log4OM and JTAlert too. I dont use Slicemaster but I have separate instances of Wsjtx that I open manually. But they are all working fine now.
Then only thing is that the lookup window on GT only works with whatever slice is active on the main screen of GT and not with the others, but that is something that Tag (from GT) is looking at for further developments and is not a deal breaker for me.
Thanks and 73.
Santiago, HI8SMX
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
