Are you getting the best receiver performance out of your FLEX-6000?
Tim - W4TME
Administrator, FlexRadio Employee admin
In order to get the best receiver performance out of your radio, you have to optimize the signal to noise ratio (SNR) based on band conditions and the ambient noise that your receive antenna is picking up. Optimizing the receiver SNR is a fairly straightforward thing to do and it is done by making sure you have the RF preamp set correctly and, this is the real important part, you have the AGC set properly. Properly adjusting the AGC is done by using the AGC-T control, which is an often overlooked feature in SmartSDR, but the most powerful one for mitigating noise and optimizing the receiver SNR.
A detailed description of how the AGC in SmartSDR works and even more importantly, how to properly set it is covered in the updated HeldDesk article How does the Automatic Gain Control (AGC) work in SmartSDR.
I highly recommend taking a look at this article as a properly configured AGC can make the difference between getting that weak on in the log or not.
9
Another great article from the Hardest Working Man in Customer Experience!! Thanks you wooly bear you!2
THANK YOU TIM! I am so grateful for this. I've had my Flex about 9 months and love it. But I admit I'm not up to speed on how best to adjust my 6400M for best receiver performance. This came at just the right time.
appreciatively
Tom KB5RF0 -
That's my boy!
This is awesome Tim.
A very important article Tim. I always felt that the AGC-T is the least understood feature in SSDR.
Agree that the AGC-T control is a very useful Flex feature. Hope that there will be follow-on improvements such as an option for automated AGC-T, or at least a visual display of the AGC-T setting.
Howard
4 -
Thanks Tim, as a new user (8 months) this article is invaluable.0
Is there a you tube on this?1
In FT8 mode, I set the AGC-T so that FT-8's green thermometer reads about 30 on a quiet band. I set the AGC speed setting to "off." Is this speed setting correct?
Good question. The answer is "it depends". Setting the AGC to OFF turns off the AGC algorithm altogether so you have to be careful about how you set the AGC-T so that you are not adding too much fixed gain to the recovered audio. Using SLOW enables the AGC algorithm and can be beneficial to reduce the volume when there is external short-lived noise sources such as lightning crashes.2
Neil, SDR provide high passband dynamic range and better do not use AGC at all with digital mods but utilize necessary filters for station selection. My AGC-T n Digi usually within 10-15 points without overloading receiver2
Thanks Tim, Great article!!!
- 337 Community Topics
- 605 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 401 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 185 FLEX-8000 Signature Series
- 913 Maestro
- 885 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 952 Third-Party Software
