Rx audio stuttering when turning on sdr have to click off sdr and restart then is fine have brand n
Joseph Coffaro
Rx audio stuttering when staring sdr
How are you routing audio from the radio? To headphones or speakers connected directly to the radio hardware or through your PC using PC Audio?0
HDMI to monitor but still does the same on the pc screen lan from receiver to pc0
So, you are routing all your audio from the radio to a laptop. I suspect the problem is with your PC sound card. You may want to try updating the drivers.
I also suspect that if you connect speakers or headphones directly to the radio, this problem will not occur, confirming my suspicion.0 -
Thanks0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
