Rx audio stuttering when turning on sdr have to click off sdr and restart then is fine have brand n
Joseph Coffaro
Joseph Coffaro Member ✭✭
edited February 2020 in FLEX-6000 Signature Series
Rx audio stuttering when staring sdr
    How are you routing audio from the radio?  To headphones or speakers connected directly to the radio hardware or through your PC using PC Audio?
  • Joseph Coffaro
    HDMI to monitor but still does the same on the pc screen lan from receiver to pc
    So, you are routing all your audio from the radio to a laptop.  I suspect the problem is with your PC sound card.  You may want to try updating the drivers.
    I also suspect that if you connect speakers or headphones directly to the radio, this problem will not occur, confirming my suspicion.
  • Joseph Coffaro
