Rx audio stuttering when turning on sdr have to click off sdr and restart then is fine have brand n
Joseph Coffaro
Rx audio stuttering when staring sdr
How are you routing audio from the radio? To headphones or speakers connected directly to the radio hardware or through your PC using PC Audio?0
HDMI to monitor but still does the same on the pc screen lan from receiver to pc0
So, you are routing all your audio from the radio to a laptop. I suspect the problem is with your PC sound card. You may want to try updating the drivers.
I also suspect that if you connect speakers or headphones directly to the radio, this problem will not occur, confirming my suspicion.0 -
Thanks0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
