TCP API TX filter bandwidth syntax
David
David Member ✭✭
edited February 2020 in SmartSDR API
I have looked through the documentation for TCP API but cannot find the syntax for setting the TX filter bandwidth.
  • bobby
    bobby Member ✭✭
    Here ya go ...
        'Sets Tx BW Lo = 200 Hi = 3000
        "transmit set filter_low=200 filter_high=3000"
        'Sets Tx BW Lo = 200 Hi = 2300
        "transmit set filter_low=200 filter_high=2300"
  • David
    David Member ✭✭
    That is what I was looking for but was not finding it in the TCP API documentation. I would expect to be list on the transmit options. Here is the syntax used to test with a raw telnet session to the radio on port 4992.
    c99|transmit s filter_low=200
    c99|transmit s filter_high=2600
    http://wiki.flexradio.com/index.php?title=TCP/IP_transmit
    Thank you for the information.
  • bobby
    bobby Member ✭✭
    I run a custom built program which searches all the api files and for each api file creates a text file listing any finds that start with send command. Then I can just open the created files with a text editor to view all the available commands the wiki is so outdated and non existant since flex changed the api now. Im still on 2.4.9.
  • bobby
    bobby Member ✭✭
    same command you just used the s for set so it should have worked I would think.
  • David
    David Member ✭✭
    Yes, I was providing an example of what I used to test it successfully for anyone else that might have the question.
  • David
    David Member ✭✭
    Are you willing to share your script? What did you write the script in?
  • bobby
    bobby Member ✭✭
    It is actually part of my vb flex control project. Here are pics API files put as extracted into the API directory (dirstr picture) the generated text files for each api file are in the APIReports directory with an .api extension but are text files with the results. (dapirpt picture) I have included the subroutine code that does that. Im sure it could be done externally with just Gwbasic or any language that will open, read, and write files. Its just all strings and the instring find function them formatting the results in a readable format and writing it to another file in text format.
    I just did it within so all I have to do is press a button to do it or again to do it over.
    Below are the pics and code.
    Code follows:
    'PURPOSE
    'Searches all API Files in the
    'API Directory for the SEND COMMAND
    'string and then writes all the
    'SEND COMMANDS to a related API
    'named file for development use.
        'Local Variables
        Dim N As Integer:                        ' Number
        Dim TFNS As Single:                      ' Tgtfilename start string
        Dim TFNE As Single:                      ' Tgtfilename end string
        Dim APISL As Integer:                    ' Start Location
        Dim CC As Single:                        ' Command Instance Count
        Dim LNData As String:                    ' Line Data
        Dim RLC As Single:                       ' Line Count
        Dim ReportFileName As String:            ' Report File Name
        Dim RFN As String:                       ' API Filename less extension
        Dim APILimiter(10) As Long:              'Location of end of Filename
        Dim CmdCount As Long:
        Dim EN As String
        Dim OFilename As String
        'Initializations
        'Anything preceeded by
        'Main. is a reference to
        'a definition or object
        'in the Main program form.
        Main.RDisplay.Text = ""
        Main.FDisplay.Text = ""
        Main.NDisplay.Text = ""
        Main.FDisplay.Visible = False
        'Gets the Target File for Report
        'from the user
        Main.ReportDialog1.Flags = &H800& Or &H2& Or &H8&
        Main.ReportDialog1.Filename = BaseDrive & BaseDirectory & APIDirectory & "*.cs"
        Main.ReportDialog1.ShowOpen
        If Main.ReportDialog1.Filename = "" Then Exit Sub
        TargetFile = Main.ReportDialog1.Filename
        Open Main.ReportDialog1.Filename For Input As #1
        'Prepare the oupput ReportFile
                'Adjust for short date
                DSM = Mid(Date, 1, 1)
                DSD = Mid(Date, 3, 2)
                If Left(DSD, 1) = "/" Then DSD = Mid(Date, 4, 2)
                If Val(DSD) < 10 Then
                        DSD = "0" & Left(DSD, 1)
                End If
                'ReportsPath is the APIReports directoy to store the result files
                'The orignal API files are in the API directory
                OFilename = ReportsPath & "CollectAPI" & DSM & DSD & ".txt"
        'Extract API Filename
        'without extension
        'Identify start string location
        APISL = 1
        For N = 1 To 10
            APILimiter(N) = InStr(APISL, TargetFile, """)
            APISL = APILimiter(N) + 1
            If (APISL - 1) = 0 Then Exit For
        Next
        For N = 1 To 10
            If APILimiter(N) = 0 Then
                TFNS = APILimiter(N - 1)
                Exit For
            End If
        Next
        'Identify end string location
         APISL = 1
        For N = 1 To 10
            APILimiter(N) = InStr(APISL, TargetFile, ".")
        Next
        For N = 1 To 10
                TFNE = APILimiter(N - 1)
                Exit For
            End If
        Next
        'Create Report Name
        RFN = Mid(TargetFile, TFNS, (TFNE - TFNS))
        ReportFileName = RFN & ".api"
        'Initialize the Report File
        ReportFile = BaseDrive & BaseDirectory & APIReportsDirectory & ReportFileName
        Open ReportFile For Output As #2
        Open OFilename For Output As #5
        'Collection file header
        Print #5, " ********************************** "
        Print #5, ReportFileName
        Print #5, " "
        'Create and Format the Report File
          CC = 0: RLC = 0
         Do While Not EOF(1)
            Line Input #1, LNData
            RLC = RLC + 1
            CmdCount = InStr(LNData, "SendCommand")
            If CmdCount > 0 Then
                CC = CC + 1
                Print #2, "Line: " & RLC & " - " & LNData
                Print #5, "Line: " & RLC & " - " & LNData
            End If
          Loop
          Print #2, " "
          'Collection File Footer
          Print #5, " "
          Print #5, " "
          Print #2, "There were " & CC & " occurances of Send Command in this file."
          Print #5, "There were " & CC & " occurances of Send Command in this file."
        'File Read and Created close all files used
        Close #1
        Close #2
        Close #5
        'Show created report in viewer automatically
        Dim IL1 As String
        Open ReportFile For Input As #1
        'Handle Report Text File this way
            Do Until EOF(1)
                Line Input #1, IL1
                Main.RDisplay.Text = Main.RDisplay.Text & vbCrLf & IL1
            Loop
            Main.RDisplay.Visible = True
            Main.RDisplay.Refresh
            Close #1
            GoTo Done
    E:
        EN = MsgBox("Error Number: " & Err.Number & " Occured", vbCritical)
    Done:
        On Error GoTo 0
        Unload Me
        Do While Not WFC
            DoEvents
        Loop
  • bobby
    bobby Member ✭✭
    Now that you brought it up I could not find it in the API files either, however I have so much API stuff and wasnt able to find it, I'm sure I obtained it another way by using a network monitor or something monitoring the commands sent/recvd across the TCP/IP connection either to the radio or smartsdr during operations. In fact that is how I find much of the undocumented stuff I am using.
  • bobby
    bobby Member ✭✭
    Found them late last night in the Radio.cs api file.
  • bobby
    bobby Member ✭✭
    David, see my latest post with the ListApi program includes a link to the project folder with source files, compiled program and info. Written after you ask here in PowerBasic Command Compiler 6.04 52k in size includes everything no bloatware!
  • David
    David Member ✭✭
    Is SendCommand the only string you are searching for in the files?
    As an alternative the following is what I did on my linux host at the root of the FlexLib_API unzipped directory.
    Without filenames
    grep -ri --no-filename SendCommand * | awk '{ sub(/^[ ]+/, ""); print }'|grep -v '^//'|sed 's/_radio.//'|grep '^SendCommand'| sort -u|less
    With filenames
    grep -ri SendCommand * | awk '{ sub(/[ ]+/, " "); print }'|grep -v '^//'|sed 's/_radio.//'| sort -u|less
    Other option to the |less at the end
    Browse results
    |less
    Line count
    |wc -l
    write to file
    > allAPI.txt
    Thank you for sharing.
