TCP API TX filter bandwidth syntax
David
I have looked through the documentation for TCP API but cannot find the syntax for setting the TX filter bandwidth.
Here ya go ...
'Sets Tx BW Lo = 200 Hi = 3000
"transmit set filter_low=200 filter_high=3000"
'Sets Tx BW Lo = 200 Hi = 2300
"transmit set filter_low=200 filter_high=2300"
That is what I was looking for but was not finding it in the TCP API documentation. I would expect to be list on the transmit options. Here is the syntax used to test with a raw telnet session to the radio on port 4992.
c99|transmit s filter_low=200
http://wiki.flexradio.com/index.php?title=TCP/IP_transmit
c99|transmit s filter_high=2600
Thank you for the information.
I run a custom built program which searches all the api files and for each api file creates a text file listing any finds that start with send command. Then I can just open the created files with a text editor to view all the available commands the wiki is so outdated and non existant since flex changed the api now. Im still on 2.4.9.0
same command you just used the s for set so it should have worked I would think.0
Yes, I was providing an example of what I used to test it successfully for anyone else that might have the question.
Are you willing to share your script? What did you write the script in?
It is actually part of my vb flex control project. Here are pics API files put as extracted into the API directory (dirstr picture) the generated text files for each api file are in the APIReports directory with an .api extension but are text files with the results. (dapirpt picture) I have included the subroutine code that does that. Im sure it could be done externally with just Gwbasic or any language that will open, read, and write files. Its just all strings and the instring find function them formatting the results in a readable format and writing it to another file in text format.
I just did it within so all I have to do is press a button to do it or again to do it over.
Below are the pics and code.
Code follows:
'PURPOSE
'Searches all API Files in the
'API Directory for the SEND COMMAND
'string and then writes all the
'SEND COMMANDS to a related API
'named file for development use.
'Local Variables
Dim N As Integer: ' Number
Dim TFNS As Single: ' Tgtfilename start string
Dim TFNE As Single: ' Tgtfilename end string
Dim APISL As Integer: ' Start Location
Dim CC As Single: ' Command Instance Count
Dim LNData As String: ' Line Data
Dim RLC As Single: ' Line Count
Dim ReportFileName As String: ' Report File Name
Dim RFN As String: ' API Filename less extension
Dim APILimiter(10) As Long: 'Location of end of Filename
Dim CmdCount As Long:
Dim EN As String
Dim OFilename As String
'Initializations
'Anything preceeded by
'Main. is a reference to
'a definition or object
'in the Main program form.
Main.RDisplay.Text = ""
Main.FDisplay.Text = ""
Main.NDisplay.Text = ""
Main.FDisplay.Visible = False
'Gets the Target File for Report
'from the user
Main.ReportDialog1.Flags = &H800& Or &H2& Or &H8&
Main.ReportDialog1.Filename = BaseDrive & BaseDirectory & APIDirectory & "*.cs"
Main.ReportDialog1.ShowOpen
If Main.ReportDialog1.Filename = "" Then Exit Sub
TargetFile = Main.ReportDialog1.Filename
Open Main.ReportDialog1.Filename For Input As #1
'Prepare the oupput ReportFile
'Adjust for short date
DSM = Mid(Date, 1, 1)
DSD = Mid(Date, 3, 2)
If Left(DSD, 1) = "/" Then DSD = Mid(Date, 4, 2)
If Val(DSD) < 10 Then
DSD = "0" & Left(DSD, 1)
End If
'ReportsPath is the APIReports directoy to store the result files
'The orignal API files are in the API directory
OFilename = ReportsPath & "CollectAPI" & DSM & DSD & ".txt"
'Extract API Filename
'without extension
'Identify start string location
APISL = 1
For N = 1 To 10
APILimiter(N) = InStr(APISL, TargetFile, """)
APISL = APILimiter(N) + 1
If (APISL - 1) = 0 Then Exit For
Next
For N = 1 To 10
If APILimiter(N) = 0 Then
TFNS = APILimiter(N - 1)
Exit For
End If
Next
'Identify end string location
APISL = 1
For N = 1 To 10
APILimiter(N) = InStr(APISL, TargetFile, ".")
Next
For N = 1 To 10
TFNE = APILimiter(N - 1)
Exit For
End If
Next
'Create Report Name
RFN = Mid(TargetFile, TFNS, (TFNE - TFNS))
ReportFileName = RFN & ".api"
'Initialize the Report File
ReportFile = BaseDrive & BaseDirectory & APIReportsDirectory & ReportFileName
Open ReportFile For Output As #2
Open OFilename For Output As #5
'Collection file header
Print #5, " ********************************** "
Print #5, ReportFileName
Print #5, " "
'Create and Format the Report File
CC = 0: RLC = 0
Do While Not EOF(1)
Line Input #1, LNData
RLC = RLC + 1
CmdCount = InStr(LNData, "SendCommand")
If CmdCount > 0 Then
CC = CC + 1
Print #2, "Line: " & RLC & " - " & LNData
Print #5, "Line: " & RLC & " - " & LNData
End If
Loop
Print #2, " "
'Collection File Footer
Print #5, " "
Print #5, " "
Print #2, "There were " & CC & " occurances of Send Command in this file."
Print #5, "There were " & CC & " occurances of Send Command in this file."
'File Read and Created close all files used
Close #1
Close #2
Close #5
'Show created report in viewer automatically
Dim IL1 As String
Open ReportFile For Input As #1
'Handle Report Text File this way
Do Until EOF(1)
Line Input #1, IL1
Main.RDisplay.Text = Main.RDisplay.Text & vbCrLf & IL1
Loop
Main.RDisplay.Visible = True
Main.RDisplay.Refresh
Close #1
GoTo Done
E:
EN = MsgBox("Error Number: " & Err.Number & " Occured", vbCritical)
Done:
On Error GoTo 0
Unload Me
Do While Not WFC
DoEvents
Loop
Now that you brought it up I could not find it in the API files either, however I have so much API stuff and wasnt able to find it, I'm sure I obtained it another way by using a network monitor or something monitoring the commands sent/recvd across the TCP/IP connection either to the radio or smartsdr during operations. In fact that is how I find much of the undocumented stuff I am using.
Found them late last night in the Radio.cs api file.0
David, see my latest post with the ListApi program includes a link to the project folder with source files, compiled program and info. Written after you ask here in PowerBasic Command Compiler 6.04 52k in size includes everything no bloatware!
Is SendCommand the only string you are searching for in the files?
As an alternative the following is what I did on my linux host at the root of the FlexLib_API unzipped directory.Without filenames
Other option to the |less at the end
grep -ri --no-filename SendCommand * | awk '{ sub(/^[ ]+/, ""); print }'|grep -v '^//'|sed 's/_radio.//'|grep '^SendCommand'| sort -u|less
With filenames
grep -ri SendCommand * | awk '{ sub(/[ ]+/, " "); print }'|grep -v '^//'|sed 's/_radio.//'| sort -u|less
Browse results
|less
Line count
|wc -l
write to file
> allAPI.txt
Thank you for sharing.
- 692 The Flea Market
