SDR-Bridge v1.6.4 compatible with Slice Master spot display
Greetings SDR-Bridge users,
I'm working on a new version of SDR-Bridge that has new features including the ability to display spots in SmartSDR. In the mean time, I suggest using Don K1DBO's Slice Master to process spots coming from your SDR-Bridge Skimmers. It's very easy to set up. On the Slice Master Spot Sources list, put entries like
The latest SDR-Bridge is available on the web site, at http://www.qrv.com/sdrbridge.
73 Ed W2RF
telnet://F1EX@localhost:7310and so on. This is working great for me. Thanks to Don for a really neat program. And look forward to a new version of SDR-Bridge, coming soon!
73 Ed W2RF
2
I'm running SliceMaster to bring up CW Skimmer, but not running SDR-Bridge. I seem to be limited to 6 KHz of decoded bandwidth, even though I have set the sampling rate to 192,000 in both DAXIQ and CW Skimmer.
Do I need to run SDR-Bridge in order to get more bandwidth?
Thanks.
73, Frank KF6E
Frank,
Are you talking about the width of the display or the width of the decode?
The display width depends on the size of your monitor. CW Skimmer doesnt offer a zoom out feature for its display. Your only option is to make the window taller. Even that is to be limited to about 24khz. (I cant quite fill two stacked 1080 monitors).
The decode width depends on the DAXIQ sampling rate. Your decodes should still be catching spots outside of what is displayed and those spots should be showing up in your SSDR panafall.
SDR-Bridge and Slice Master differ in how they handle launching and telling CW Skimmer where to decode. But both are subject to the limitations of CW Skimmer's display.
--Don
Hi Frank,
As Don noted, the vertical CW Skimmer display is limited by the height of the window that your monitor settings support.
I submitted an idea to directly integrate CW Skimmer with SSDR that would flip the display horizontally and expand the bandwidth displayed significantly. It would also eliminate the redundant waterfall display (it is on both SSDR and Skimmer currently) taking up monitor space . The Skimmer display, when turned on, would be as wide as the SSDR display and right below the SSDR waterfall. Here is a snapshot showing a small part of the display below the waterfall.
Check out the idea here and add your comments and a vote if you would like to see this feature. BTW, Alex ( CW Skimmer author) is working on a completely new version that could make the direct integration with SSDR easier. On a related note, I asked Alex about providing an option for a horizontal waterfall for Skimmer. Not sure if he will do this in the new version but that would be another way to display a wider bandwidth in the Skimmer application.
Link to the SSDR and CW Skimmer integration idea:
https://community.flexradio.com/flexradio/topics/pfskimer_what_is_the_possibility_for_a_smartsdr_display_that_combines_panadapter_waterfall_cw_skimmer
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
- 392 Community Topics
- 668 The Flea Market
- 173 SmartSDR+
- 448 SmartSDR for Mac
- 266 SmartSDR CAT
- 214 DAX
- 388 SmartSDR API
- 70 Aurora
- 312 FLEX-8000 Signature Series
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
