Is it possible to associate an antenna/receiver input to each band?
Jeremy - W2JG
Is it possible to associate an antenna/receiver input with a band? As I change frequencies/band either manually or through a memory channel select, it appears I also have to select the receive input as well. Am I missing a setup step or do I have to select the antenna/receiver input each time? It sure would be nice to have the selection part of the memory file.
Thank you for your assistance!
Jeremy
W2JG
Jeremy
W2JG
What radio and version of SmartSDR are you using?1
I am running the latest version 3 on a 6700.0
Thanks for the info. There are a few ways to do this. Band persistence which is operating all the time will remember the slice and antenna configuration when you return to the band using the band button to change bands. However, since band persistence is dynamic it can get overwritten and might not be 100% reproducible.
One other option, and it is the one I use because it is 100% reproducible is to define global profiles for the bands and antenna configuration you want to use. For example, I have an HF antenna on ANT-1 and a 6m beam on ANT-2.
I have 4 global profiles defined. One is for 6m (ANT-2) without using an amp (100W RF power setting) and one for 6m when I use the amp (25W RF power setting). I have the same pair defined for HF that uses ANT-1.1 -
Thanks!
I did not see the Band Persistence doing what you mentioned, but I could be wrong. I use the Receive B input for 2m and Receive A for the 70cm band.
Just checking, the Global Profiles have to be swapped manually and are not changed when the band is changed, correct?
It would be great if the antenna input could be added to the memory file in the future. That would make for quick channel changes.
Thanks Again!
Jeremy
W2JG
Yes.1 -
Ok, thanks! This closes my question.0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
