6600M frequency display freeze while tuning
Doug - W5WTX
Running 6600M with SDR V2.6.1. The frequency display freezes while tuning. I have to stop turning the VFO knob for the display to catch up. Same issue on any slice receiver. If this topic has been previously discussed I would appreciate being pointed in the right direction. If not, is anyone else seeing this or know of any solutions.
Yes, I sometimes see this on my 6600 + Maestro and have discussed it in posts before. I do not see it as often running Wifi (strangely) vs. wired ethernet to the same router, and I have no clue what causes it. Sometimes it is snappy and tracks perfectly. Other times there is a lag significant enough that trying to dial in a frequency is a hit/miss thing because it won't update the display until tuning is stopped. At least, that's what I see. Since I moved to the Wifi connection for the Maestro I don't see it nearly as often, but it is still there sometimes. (and when I'm using the rig, the router is not busy doing anything else.)
Doug, does it still have that problem when not connected to your network? Using the radio simply as stand alone?
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
