6600M frequency display freeze while tuning
Doug - W5WTX
Running 6600M with SDR V2.6.1. The frequency display freezes while tuning. I have to stop turning the VFO knob for the display to catch up. Same issue on any slice receiver. If this topic has been previously discussed I would appreciate being pointed in the right direction. If not, is anyone else seeing this or know of any solutions.
Yes, I sometimes see this on my 6600 + Maestro and have discussed it in posts before. I do not see it as often running Wifi (strangely) vs. wired ethernet to the same router, and I have no clue what causes it. Sometimes it is snappy and tracks perfectly. Other times there is a lag significant enough that trying to dial in a frequency is a hit/miss thing because it won't update the display until tuning is stopped. At least, that's what I see. Since I moved to the Wifi connection for the Maestro I don't see it nearly as often, but it is still there sometimes. (and when I'm using the rig, the router is not busy doing anything else.)
Doug, does it still have that problem when not connected to your network? Using the radio simply as stand alone?
