CW-SSB at HRD DM780 Issue Un-Key Delay
YG6HBC
Im using flex6400 and I have download and install HRD and run cw via DM780 in mode CW-SSB. The problem when Im run the key and when un-key have DELAY l time 0.5-1 second to unkey. Whats the problem or what must I do with setting ? Thank you as you care.
please share config between the 20
Here is screenshot
The problem is, when I run CW-SSB at DM780 at first start is normal but in the end of transmit CW-SSB the Un-key is delay 0.5 - 1 second
I can take more screenshot about config that you need to see (check). Thank you.
This sounds like the dreaded CAT command congestion that previous versions of HRD experienced and was resolved by using the MiniDeluxe software to simplify and reduce the number of CAT commands HRD sends to the radio.
https://github.com/krisp/MiniDeluxe/wiki
Hello Tim, I have download and run MiniDeluxe but im confused what must I do. Please tell me what must setup with MiniDeluxe as like screenshot that I have paste
My Radio Flex 6400 in Com8
Only run DM780 and the logbook. DO not run the rest of HRD.
DM780 Notes
It may be necessary for you to create a new identity inside DM780 in order to connect to MiniDeluxe. If this is the case, try the following procedure:- Start MiniDeluxe.
- Start DM780, select File menu -> Identities
- Click new and name it something.
- Select it from the list and click Select.
- Once DM780 re-opens, click the radio tab and click the configure button.
- Click the connect button. You should see the six buttons for Mode, AGC, etc, and a TX button.
- Click save and see if it's working.
HRD Logbook Notes
If you are having problems getting the mode and other buttons to update in HRD Logbook, please follow this procedure:- Start MiniDeluxe and PowerSDR
- Open HRD Logbook
- On the radio pane, click Options
- Click Connect followed by Defaults
- Switch to the Default Layout tab
- Click each of the six drop-down buttons at the top and choose one of the six selections from the list.
- Click OK
Here is my SmartSDR Cat
When I run MiniDeluxe its fail like as this screenshot. What must I do ? I have choose Com8 but it was error or access denied
I can not Run MiniDeluxe
My HRD V6.7
Tim...its MiniDeluxe compatible with my HRD Lastest version ?
That's a good question. I don't know. I don't use HRD products in my operating position. You may want to contact HRD support about your original issue. I know they do not support MiniDeluxe.0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
