Newbie question
Jim
Com ports question......... I’m running a Flex 6400. I have log4om set up and running fine. I want log4om to run anytime the Flex is running. Sometimes I want to use WSJT-X and sometimes I want to run FLDIGI. Do all these third party applications require their own individual com port even though they won’t be running at the same time? Thanks in advance, 73’s. KC3KRZ
Two running apps can not share a com port. So you can either come up with a complicated system to enforce the various combinations or you can create a unique virtual com port for every application.
The latter is far simpler and has to be done once.
73, K8RC1 -
So you just define more virtual SmartSDR CAT ports for each slice, you can have a bunch for each slice and can dedicated each port to a different ap. SmartSDR CAT will then show you which ap is using which virtual port.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
