Downgrading From v2.6.1 back to v2.4.9
L.Kubis
After weeks of struggling with the revised antenna tuning algorithm which shortened the tuning cycle, I finally decided to downgrade to my previous software version 2.4.9. Now my antenna tuner is functioning as it did and I'm able to use my Flex again.
I wonder if anyone else had a similar experience?
Cheers!
Lloyd
VE3ERQ
Cheers!
Lloyd
VE3ERQ
Wow My new preloved 6660M coming in week going have new v4.3 ??? Hope that upgrade is best .0
V4.3? What version is that?1
Upgrade for S meter you can zero it zero or leave like It is where it shows noise level with band noise all time - My old 6400M S meter read high 4-6 S units all time . NB and NR was made more user adjustable .0
Hi Lloyd.. I had to do the same thing after struggling with 2.6.1 for a long time. I just couldn't get the ATU to work consistently and not at all on some frequencies. I went back to 2.4.9 at the suggestion of Flex (and members of this community) and hoping the problem will be solved soon in a future release. The problem is known and acknowledged (sorry, I can't remember the problem # off the top of my head), so hopefully a new release will be able to let me enjoy my ATU and all the other features of 2.6.
Don
Hi Lloyd you may have just solved a mystery for me where the tuner on my 6400 appears to work but when I transmit it is not tuned. It takes three or four times to get a tune. Thai did not happen until upgraded to 2.6.1 my brain had not had clicked on the cause was assuming it was an antenna or feed and have not been able to get to the remote site since December. reading your post I know what to try before I travel up the mountain.
Cheers Steve
OK, you had me for just a moment and then it hit me.... same issue I have inquired about. I was told at a show that the 'S' meter read the signal level at the antenna and then by the same person that with the SO239 shorted, it read the ADC noise. So which is it. I can tell you proof positive that with the terminals shorted, there should be no reading on an 'S' meter unless it really does read internal noise.1
James,The person who told you that is correct on both but leaving out any reasons why. If you do a search on this subject you can find tons of information on this explained buy Steve and Eric, at Flex.
I'm back at 2.49 also... My low band antenna refuses to tune on 3.17. I miss the features on 3.17 enough though I am going to put the old sandwich powered tuner back in action for now. I use the heck out of the Flex Control and MultiFlex with the Maestro and the second PC on the desk... I'm sure the guys down in Texas will have it figured out soon. Mike W1BFA
Bill, I will keep an open mind but they are mutually exclusive. If my 'S' meter reads say "S" 4, with the antenna port shorted then it is NOT reading what is at the antenna. When a proper antenna is connected, a given 'S' meter reading is the signal voltage plus the ADC noise which is not the signal at the antenna. Jim1
Once you add an amp and/or start working two bands SO2R with a tuned antenna, the builtin antenna tuner will be unused. I have one but have not used it in many months.
edit: made it almost a day and although it was nice to have the antenna tuner back I miss the new toys too much. Back to V3!
I added an Icom 7300 to my shack, it just plain works. Even the noise filter. It doesn't crash either. The S meter reads zero on no signal. It starts in 5 seconds. Customer service may not measure up to Flex, but then again I haven't needed it.1
I also have a 7300 for portable ops together with my local club has three - That radio has an issue with front end overloading, but otherwise is a simple clean radio. Much prefer my Flex1
Coolest my Dear Friend Burt glad your still Alive and posting missed you .
I just added Expert MB1 and Yaesu Ft-991A sweet little guy and both have normal S metes —
Both have Better NB NR way better NR than my Flex 6400M but
I had No problems with Flex as I never used with a crazy computer so how could it miss behave —
with it ****
Mama Says Fools use Computers and they are for lazy people Mama says -
MB1 odd duck but she a learning experience my God is she pretty and she sounds like old Collins 2A tube radio
No noise receiver wow and I mean WOW
I1 -
Can we keep this thread on the performance of the Flex antenna tuner with V2.6.1 software pls.
Lloyd
VE3ERQ3 -
Ok Boss Yes Um Boss Yes Um Boss What a control Freak you are ****2
It is best not to high jack a thread so it is better to follow.
It is very sad that so many of us Flex owners have to go back to 2.4.9 to get our equipment to work right like it always has. Just add this to the ever growing list of defects created by new features. Too many of us are stuck on old versions. Dear Flex - please stop bringing out new features and fix some of these really bad defects.
Yes agree I use Amp and Ten Tec High Power antenna tuner No radio should have a built in Antenna Tuner most all junk ..1
Lloyd, why?
Because that was the question that was asked!1
I agree with u Lloyd.
Terry K7NY
Them not addressing this immediately is a sad commentary. I have the same issue and unfortunately can't downgrade the software remotely. I'm in FL till May and my 6500 is in Ohio. It's a **** shoot whether the tuner will work or not whenever I power up the rig. Not to compare (but I will) Elecraft would have taken care of this as soon as the problem was reported. Apple too ! Come on Flex-get with it !0
They have the fan issue first work on that shuts radio down - I was told by Oct they should start looking into antenna tuner issues - No worries it could be worse !!!!0
OCTOBER ? You've gotta be kidding. The tuner DID work. I'm crippled w/o the tuner. Not about to fly back to OH to downgrade from the current software that wasn't properly checked out before it was released.
This is what's going on I think . . . They're getting ready for another "first" they're going to announce at Hamcation. Thus the reason for the bugs not getting worked on.
Wanna Bet.
You can be sure I'll be visiting them in Orlando next week to seek a solution.
Brian I would just down load 2.49 The older program -they told me the problem from using Windows 10 it’s not Flex fault !!!0
I'd appreciate if you can tell me how to do this remotely ? As mentioned previously I'm in FL and radio is in OH.
I can tell what my wife do if I was on vacation with Her and played on Flex radio on vacation - She stick that Flex radio you know where boy that would hurt lol lol lol0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
